JD 318 sleeve hitch?
8 replies to this topic
#1 samell OFFLINE
samell
  • 2 posts
Posted December 10, 2011 - 01:43 AM
I have a 318, and some sleeve hitch implements. My problem is I don't have what is in between.
I don't think JD made an integral sleeve hitch for the 318. It appears an expensive 3-pt hitch addition is needed.
Has anyone been able to adapt a sleeve hitch to a 318?
#2 mjodrey OFFLINE
Posted December 10, 2011 - 05:17 AM
samell,welcome to the forum.Glad to have you with us.
I can't help you with your question,but someone will be along.
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted December 10, 2011 - 05:30 AM
There is an integral hitch available for the 140's and the older 300 series. You may be able to adapt that. There is a set of plans here for the sleeve hitch somewhere but I can't seem to locate them right now. If you PM me with your email address I'll send you a copy of those plans. From that you should be able to determine if you can make it work on the 318.
#4 MAV OFFLINE
MAV
  • 110 Thanks
  • 215 posts
Posted December 10, 2011 - 12:16 PM
If you have a 3pt hitch or plan on getting one you could get a A frame adapter like this.
#5 TheJDMan OFFLINE
TheJDMan
  • 4 posts
Posted December 10, 2011 - 04:24 PM
Deere never made a sleeve hitch for the 318, 322, 332 tractors because they sold a three point for them instead. As stated above you need an adaptor to convert from the three point to sleeve hitch which will be an aftermarket piece. If you don't have a three point hitch you can buy one from Ruegg Manufacturing
Hitch Kits
#6 samell OFFLINE
samell
  • 2 posts
Posted December 10, 2011 - 05:17 PM
I have seen those plans. Either on this site or WFM. I'll have to do some more investigating. Thanks for the response.
I was hoping not to have to buy a 3 point hitch for it due to the expense and then having to convert to sleeve hitch. Looks like about $450 +
Jim
#7 Tmo OFFLINE
Tmo
  • 361 Thanks
  • 486 posts
Posted December 10, 2011 - 05:25 PM
As mentioned you need the 3 point hitch and A-frame adapter like this one: Cub Cadet Parts
There are plans out there for making the A-frame adapter.
http://www.xtrememot...ages/aframe.jpg
http://www.xtrememot...ges/aframe2.jpg
#8 SonnyT OFFLINE
SonnyT
    Deceased
  • 116 Thanks
  • 125 posts
Posted December 11, 2011 - 07:31 PM
Here is a Link for JD sleeve Hitch.
http://johndeere.30....ype=post&id=260
#9 Tmo OFFLINE
Tmo
  • 361 Thanks
  • 486 posts
Posted December 12, 2011 - 07:16 AM
That's the drawing I did and that's my little picture site. That hitch is for the closed frame tractors, i.e. square fender 110/112s, 200, 208, 210, 212, 214, 216 tractors, 120 and 140 tractors, and the 300, 312, 314, 316 (with the Kohler engine), and the 317 tractors. It won't work on the open frame tractors like the 318, 316 Onan, 322, 330, and 332 tractors.
