Need pics of original pulleys
5 replies to this topic
#1 drbish ONLINE
drbish
    Collecter
  • 1,571 Thanks
  • 1,370 posts
Posted December 09, 2011 - 02:24 PM
I would appreciate some pics and dimensions of pulleys,I have not got a a clear measurement of the sizes of the pulleys just part numbers,both double pulleys on my walk behind are the same size
Edited by new restorer, December 10, 2011 - 05:19 AM.
#2 DougT ONLINE
DougT
    Dog Approved
  • 7,085 Thanks
  • 5,063 posts
Posted December 10, 2011 - 10:13 AM
You had a Plow-Trac, right? Did you ever figure who actually built it?
#3 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,676 Thanks
  • 5,052 posts
Posted December 10, 2011 - 10:56 AM
This is from a Wisconsin powered Midland. The large pulley is 3 and 7/16 inches dia. The small pulley is 2 and 15/16 inch dia. Pulley is 2 inches deep front to back. Do you need pics of the tranny pulley too?
  • drbish said thank you
#4 Gtractor ONLINE
Gtractor
  • 9,676 Thanks
  • 5,052 posts
Posted December 11, 2011 - 10:27 PM
There are several pulleys that could be on the tranny side.
This one is a multi piece stamped steel pulley that was welded together. The large side of the pulley has a diameter of 8 inches.
This one is cast aluminum, 8 inch diameter. It would give the same ratio[s] as the one above.
This is another cast aluminum pulley that also has the diameter of 8 inches as above but with the extra flange for reverse. Notice the engine pulley has 4 grooves to run the reverse belt in the inner most position.
This cast aluminum pulley is smaller having an outside dia. of 6&1/4 inches. It is on a smaller model tractor with a Clinton engine. I'm guessing 1&1/2 to 2 horsepower.
All pics are from Midland tractors. There very well may be more differences that I don't have.
  • drbish and Lauber1 have said thanks
#5 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted December 12, 2011 - 12:45 PM
Glad you posted that, i was supposed to get it done this weekend but ran out of time. I was having way to much fun out there watching the snow melt off..
#6 drbish ONLINE
drbish
    Collecter
  • 1,571 Thanks
  • 1,370 posts
Posted December 12, 2011 - 05:41 PM
Lauber 1 is that like watching paint dry,i am more confused than i was ,but there is reprint of my original service manual on e bay for 15.06 with free shipping.the number on my gear reduction is the same as the catalog number,mid -w,the way the picture looks to me i am also missing the cast iron lever on the right side ,thanks for the measurements on the tran pulleys
Edited by new restorer, December 13, 2011 - 04:58 AM.
