tires
8 replies to this topic
#1 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted December 09, 2011 - 01:55 PM
got an estimate to have my deestone ags mounted onto my cubs rear rims, going to cost 30 dollars each tire to have them mounted and fluid filled. good deal?
#2 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted December 09, 2011 - 04:01 PM
DO NOT use Calcium Chloride.
Use something non-corrosive like anti freeze, RV anti freeze, Rim Guard, or windshield washer fluid.
#3 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted December 09, 2011 - 06:12 PM
Why not mount them, and fill them yourself Ryan? It's not hard to do, and it'll save you $60.00.
#4 mixedbreed96 OFFLINE
mixedbreed96
  • 11 Thanks
  • 167 posts
Posted December 09, 2011 - 08:05 PM
im only scared because i do not have a tire installer. and how would i go about filling them
#5 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted December 09, 2011 - 08:26 PM
Here is how I did it.
http://www.youtube.com/watch?v=kkJKTGg70-U
Episode 32 - Filling my Tires - YouTube
  • Texas Deere and Horse and KennyP have said thanks
#6 mjodrey OFFLINE
  • 2,356 Thanks
Posted December 10, 2011 - 05:32 AM
:ditto:
#7 xshooter OFFLINE
xshooter
  • 34 Thanks
  • 93 posts
Posted December 10, 2011 - 10:20 PM
Here's the set up I used to fill my tires.
I took the valve core out, wrapped a ratchet strap around the tire. Then I filled the can with washer fluid and tightened the strap to burp the tire. If I remember right I got 6 gallons in a 23-10.50x12.
#8 Texas Deere and Horse OFFLINE
  • 14,814 Thanks
  • 15,501 posts
Posted December 11, 2011 - 12:46 AM
I uploaded a drawing of a pressure operated fill tank that is very easy to build and use. here is a link to it. I found this on the net.
Liquid Tire Filling Tank - Manuals - Garden Tractor Talk - Forums
I hope this helps.
#9 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted December 11, 2011 - 01:12 AM
around here one of the easiest ways to put ww fluid in a tire is to take them off. Next lay them flat core side up, let out the air. Break the bead down onthe up side and pour the fluid right in. Simply reinflate and remount and your done. This only work for those using tubelass tires. Youll have to do one of the pump in things if you got tubes.
I'd look around for a repair or big truck shop for the antifreeze, as they have to pay to get it hauled away and will almost always give you all you can haul off for free.
On the personal note, i dont ever use any fluid in my tires, as i can load up 100# of wheel weights in just a few minutes time. If you use the standard of 8# per gal 4 gls only gives you 32# a wheel, which can done and then some with one iron weight or a home made concrete one. If your using the tractor for any garden working or lawn mowing you really dont need all the extra weight. This is why i choose the removeable weights. Also the fact that most of my tires are 6x12 i could only gain 16 to 20#, hardly worth it to me.
