panzer belts
5 replies to this topic
#1 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted December 09, 2011 - 01:22 PM
my panzer 1107 needed a new belt when i got it. So i went online and looked in the manuals and it said i needed a 30in belt. When i got the belt on it was to loose so i made adjustments and it as far out as it can go and the belt still isn't grippin right. Any ideas
#2 Bolens 1000 OFFLINE
  • 15,432 Thanks
  • 18,284 posts
Posted December 09, 2011 - 04:12 PM
What kind of belt did you buy (brand)?
Alot of OEM belts had special angles on their belts which may be the reason why the new belt you got was too loose
#3 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,798 Thanks
  • 5,097 posts
Posted December 09, 2011 - 05:22 PM
My 1107 always did the same thing. If I was moving a load I had to push on the F-N-R lever. Not much adjustment on those.
#4 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted December 10, 2011 - 09:38 AM
I got a gates 30in belt. the belt before was 30 but a smaller thickness and it worked great. It just wasnt strong enough
#5 CountryLoveSales OFFLINE
CountryLoveSales
  • 9 Thanks
  • 47 posts
Posted December 10, 2011 - 01:49 PM
You have to watch belt and the way they are sized..... in my gates book it says a 1107 needs a 6934 belt.... 21/32 x 34 belt. some belt companies measure the inside of the belt while others measure he outside of the belt.
#6 Bolens 1000 OFFLINE
  • 15,432 Thanks
  • 18,284 posts
Posted December 10, 2011 - 03:53 PM
:ditto:
